5 members (Rusty Heaps, Ridgeback, Phak1, Gdads51, moparguy), 408 guests, and 5 robots.
Topics128,162
Posts1,057,040
Members48,463
#1085697 02/15/2015 1:45 PM
I know 700 R4s are made for both 2 and 4 wheel drive. I found one for 4wd for sale, but can I use it just for my 2 wheel drive? and just not use the 4wd part? 1987 and newer, 30 spline, Thats what I'm looking for. thanks,
You would need to rebuild it with a different output shaft and extension housing. The 4X4's have a short shaft and an adapter that mates the trans to the transfer case- - - -no way to connect to the rear driveshaft without the transfer case attached, and running the transfer case without the front drive equipment in place would add a bunch of weight and complexity for no good reason. Virtually all the S-10 automatic trans rigs with the V6 engine ran a 700R4, there should be thousands of them available.
OK, better. thanks. I'll find me a 2WD version.
I don't know what engine you're running, but if you get one from an S10, look for one with the 4.3 V6. The 2.8 version has a different bellhousing bolt pattern from the 4.3 and V8 engines.
Bill Burmeister
scotricker #1086088 02/17/2015 12:05 AM
Just FYI the later 4L60E's found behind LS engines have a different length input shaft. I would look for a 85-92 trans personally.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
And if you find a buy-one-get-one-free deal, PM me as I need one too, real bad right now.
Carl
scotricker #1086310 02/17/2015 11:33 PM
I would actually look for a 200-4R, not a 700R4.
My 46 GMC on Photobucket
scotricker #1086318 02/18/2015 12:04 AM
The 700 is cheaper, stronger, has better gearing, is far more common, and is rated for truck use.
Bill Burmeister
I'm a little crippled up from my motorcycle wreck, but I think I could still outrun anyone who tried to give me a 200-4R! That thing shares too many parts and pieces with the worst automatic transmission GM ever made, the Turbo 200 Metric!
Those things are completely subjective. Cheaper? It depends. Stronger? Stock yes but may not matter, depends on what engine is in the vehicle. Rated for truck use? We don't know if it matters in this case.
The 200 can be built to be stronger than the 400 and is easier to hook up, and is shorter. It's an easier swap, but the other things might outweigh that depending on its usage.
Jerry, you sum up my point exactly!
Bill Burmeister
I wish I had a 200-R4 laying around. I'd drive all the way to Dellrose, TN just to check on HRL's recovery progress. smile
Is Dellrose even on the map?
Carl
drive
52Carl #1086607 02/19/2015 3:40 PM
Carl
Both city limit signs on the same post! I'm about 40 miles NW of Huntsville Alabama, just north of the state line.
Here's a bit of Trivial Pursuit for ya- - - - -"Once upon a time" the whole world's population lived in Tennessee. When people would get caught stealing horses or chickens, cheating at cards, or stepping out on the wife, they would get so embarrassed they had to move away- - - - - - -some of us never got caught!
LOL!
Priceless!
