2 members (78buckshot, NJC),
99
Mod | | | Forums66 Topics128,149 Posts1,056,819 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | Does anyone have any ideas about reinforcing the outer perimeter of these big floppy fenders? Thanks, Scott | | | | | Joined: Feb 2008 Posts: 1,123 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,123 | They had fender braces. The braces trapped mud and water, leading to rust through. I have a rear fender in the the process of being repaired for use on my '46 project. When I removed the brace even it was badly rusted. I may leave the fender without one. A buddy is also working on his '46 and found the replacement part he'd ordered didn't fit as advertised. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Scott, I think you are talking about the outer edge of the fender lip. Correct? If so what my body man did was weld a round rod to the inside curl which makes the edge much stiffer. Then, so that no water or mud is allowed to sit in that area he used some bondo over the top of the rod and smoothed it to the inside of the fender. I know some people don't like to use bondo but it has worked for me for the last 10 years.
Hope this helps George | | | | | Joined: Feb 2011 Posts: 170 Shop Shark | | Shop Shark Joined: Feb 2011 Posts: 170 | Thank's George. What was the diameter of the round rod? | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Agree with George. Mine were cracked in a couple areas near brace and I used a 3/8 carriage bolt about 6" long and welded up. You may have to grind enough area where brace is to get a good fit. Dan | | | | | Joined: Feb 2014 Posts: 5 New Guy | | New Guy Joined: Feb 2014 Posts: 5 | I have the fender braces for the front fender but have a s-10 clip. And been trying to get them to work. And ideas. Thanks | | | | | Joined: Jan 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 45 | I am doing a 46 right now with a S10 complete frame using the kit from ez swap and the front fender braces still mounts to the radiator support. I have pre fit the front end parts and one you get all the bolts into the cab, inter fender, and radiator support those fender are pretty secure. PM me and I will see what you are doing wrong. Norm
My first prewar and it will not be my last. Done with the 40 for my best friend. Got a 46 (year I was born) to build for me.
| | | | | Joined: Feb 2014 Posts: 5 New Guy | | New Guy Joined: Feb 2014 Posts: 5 | I installed a new chevy 350 this winter and had to move the radiator support forward .I never used the supports before now getting a small crack in the fender. I might have to fab some braces to supports the fenders | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Moving the radiator support sounds like a bad idea, but I'm not sure what you mean or what you did. Could you please provide some photos so that we can try to help out?
My '46 has a full S-10 frame with a 455 Buick and I didn't move the rad support, but I did change where the rad mounts. Mind you I don't know if yours is a Chevy or GMC. They had different rad supports. | | | | | Joined: Feb 2014 Posts: 5 New Guy | | New Guy Joined: Feb 2014 Posts: 5 | Got the fender braces on .It's a 46 Chevy . Thanks for the help | | | | | Joined: Jan 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 45 | On the 40 I did for best friend and my 37 I relocated the radiator forward on the support to get me more room for the motor, but when you more the support you throw all the front end parts location off. You are going to have put the radiator support back to the correct location and move the radiator. On the 40 we move it to other side support mounting point and put some spacer on it, we also had to modified the grille upper filler pan at the rear so it would not hit the radiator. I agree with 46gmcpu that yo will have change where you mount the radiator to the support on the 46. Send pictures and good luck
