| | | Forums66 Topics128,088 Posts1,056,390 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 32 New Guy | | New Guy Joined: Jan 2015 Posts: 32 | It seems most pictures I see of the lever door handles, they are not horizontal. Most are hanging down 1/2 to 1" and I just saw one that was actually tilted UP.
I prefer the looks of the lever handle to the push button, and that is one of several reasons I'm looking for an earlier model. But having the lever not dead horizontal would drive me nuts.
Is there a big issue with lining them up? Is it simply a matter of wear that causes them to sag? Are they adjustable?
Please help me understand.
Thanks!
Thanks, David
| | | | | Joined: Mar 2010 Posts: 10,286 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,286 | It can be caused by rust/dirt, bad spring, worn metal on the square end of the handle shaft. It is more work than most people want to do, or are afraid that they can't fix it. It doesn't affect the operation of the door latch. Mine will stay put in the proper alignment if I put it there after I close the door. Aftermarket latches are said to be junk and old originals are challenging to repair. Carl
| | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | The handles are a press fit on the shaft and a heavy hand yanking down to open the door can cause it to rotate out of position. The handle can be re-aligned and pinned in place, as I saw on an old posting here on Stovebolt. I also had some luck in bumping the handle back to its original position while still in the door by hitting it up with heel of my hand. That might work for awhile but if it moves easily back into position it will also move easily back out of position! | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jan 2015 Posts: 32 New Guy | | New Guy Joined: Jan 2015 Posts: 32 | Good info - thanks. Mine aren't sagging though. I could throw in a comment about the missus here, but I won't. You value your life?
Thanks, David
| | | | | Joined: Mar 2010 Posts: 10,286 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,286 | Mine aren't sagging though. I could throw in a comment about the missus here, but I won't. Dude! You just did. She must also be a blonde, if you figure she won't guess what its about.  Carl
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I slap an angle finder on the handle in the sagged down position and see how many degrees it's off horizontal. Remove handle, clamp square end in vise, heat red hot and twist shaft up the number of degrees it was down. You must hold handle in line while twisting or the shaft will bend to one side or other. When reinstalled the handle will often point up with the door open but drop back horizontal when shut. This eliminates the spring having to retain it's tension. The latches were of such a terrible design that I refuse to let a truck leave the shop without bear claw latches or at least safety belts. If they don't want either they can take them somewhere else. Many a kid, including me, has fallen out of one of these trucks when a door popped open.
Evan
| | | | | Joined: Jan 2015 Posts: 32 New Guy | | New Guy Joined: Jan 2015 Posts: 32 | I slap an angle finder on the handle in the sagged down position and see how many degrees it's off horizontal. Remove handle, clamp square end in vise, heat red hot and twist shaft up the number of degrees it was down. You must hold handle in line while twisting or the shaft will bend to one side or other. Sounds like a good plan as well. Thanks!
Thanks, David
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Evan, I see you have a restoration shop. So I'm having a little problem understanding your definition of a 'restoration'. Which I thought was the process of repairing the degraded aspect of an automobile or truck with the purpose of returning it to an overall "authentic" condition. By cutting away parts of a pristine door and adding a completely different design of door latch it would seem to me that it should then be referred to as a custom job, not a ‘restored’ vehicle. Not to say that there aren't cases where the doors did fly open, where the original door latches were worn out or they were maladjusted or the door simply wasn't closed completely in the first place. Also people have been known to bump the handle with their knee or hook it with their sleeve releasing the door latch. I grew up on Chevy cars and trucks, getting my first one in the late 50's and owning many more over the years. My full time work was at Chevrolet dealerships from '59 through the mid 60's at which time my uncle called me. It’s now 57 years later and I’m still owning Chevy’s and I've never seen the doors fly open on a Chevy Car or Truck of any vintage unless one of the previous conditions were present or occurred. Do door lock wear after 65 years of use? Of course they do. Are they difficult for the average person to repair? Of course they are. From the reports I’ve heard about the stock appearing aftermarket replacement locks, they’re not quite up to snuff either. I’ve got a pair somewhere here in the barn that I’ve never had occasion to use and they look at first glance just like the original ones. I haven’t had a chance to evaluate them so I can’t comment on how they fit or operate. But all that still isn’t a good enough reason to modify a perfectly good door with a completely new design.
Just for those that are thinking of 'customizing' your doors or ‘up-grading’ or ‘personalizing' or 'modifying' or whatever you choose to call it, I've been hearing of problems with the way the straight 'bolt-in' 'Bear Claws' are a little less than perfect also. Specifically alignment problems with the handles after cutting away the back end of the door. A large number of the so called 'bolt-in' kits or products on the market require modification or adaption which in many cases, the average guy simply isn't equipped to tackle. If I were 'customizing' my truck I would ask around a bunch before I cut my perfectly good doors apart leaving no path to turn back from. A couple thousand ‘Bear Claws’ sold over the last few years compared to millions upon millions of GM latches designed and installed at GM plants over the decades does not necessarily make it a well proven design in my book. And that’s just my take on the subject. Denny Graham Sandwich, IL
Denny G Sandwich, IL
