| | | Forums66 Topics128,014 Posts1,055,329 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | I have a 1953 Chevy truck that I'm restoring and I had the leaf springs rebuilt and I have had it on jack stands for three years and I took it off jacks last week and I noticed it seems to lean lower on the passenger side . Does anyone know what could cause this . Could it be a twisted or bent frame ? Thx | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Sal,I'll assume the truck was on stands on a level surface so it's unlikely the chassis will have tweaked unless it was twisted before you jacked it up. Bear in mind the rebuilt springs have also been decompressed for three years they simply could dry and be binding.
Have you driven it since?
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you are wondering if the frame is bent from sitting on jack stands, the answer is no. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Did your truck come with the driver's side bedside tire mount? GM added a lowering block on the passenger side rear spring mount to level out the frame from the extra weight of the spare and the bracket on the opposite side. Carl
| | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | No the spare tire mount is under frame | | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | When u say binding what exactly does that mean ?If the frame is bent how do I go about fixing that and does the truck need the be pulled back apart | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | First you need to find out if it is actually bent. Put jack stands at 4 corners on a very flat surface. If the jacks are exactly the same height, one corner will be off of the jack if the frame is twisted. Carl
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Did you lay one spring on top of the other to see if the arch is the same after rebuilding. Even if the arch is the same the rate could be different on a used spring so one would sag more than the other under the same load. Swap sides to verify that it's the springs and not the frame.
Evan
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Sal,by binding I was meaning the individual leaves of the springs may be dragging slightly rather than sliding under compression. If they have been sitting in a fixed position for three years it's entirely possible a small amount of rust has formed between them causing them to 'bind'. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
