1 members (NJC), 78 guests, and 0 robots.
Topics128,035
Posts1,055,564
#1084869 02/10/2015 6:16 PM
1 Offline
So my '42 and '46 both have replacement engines with no stamps. Are there any other places on the body, frame, that may have some sort of ID? I'd really like the try and find the history of the 1942 but I keep running into dead ends.
1942 BK 1/2 Ton Pickup
1954 3800 1 Ton Pickup
1942 Vehicle Number
"Stamped on plate on right side of cowl under hood"
1946 Vehicle Number
Do you have a title or registration?
engine numbers were used most places as the title "vin" back then, so if you're talking about ownership history tracking, you're likely out of luck .... nothing on the frames in the 40's, the only other identification number of interest would be the factory serial and model ID number plate that should be on the pass side cowl under the hood, but that'll just confirm the year
1 Offline
That's what I was afraid of. That's too bad. Thanks for the help.
