5 members (Tronman, Otto Skorzeny, TUTS 59, Millenimech, 1 invisible), 116 guests, and 3 robots.
Topics128,042
Posts1,055,509
Members48,424
#108483 03/30/2005 11:20 PM
PJ
Offline
Couple questions: New at this, keep that in mind.
How do you determine the difference between a C10 & C20
I have a 65 longbed stepside, is it possible to take the cab off a 64 fleetside shortbed and it fit on the chassis correctly?
James.
#108484 03/31/2005 12:02 AM
To tell the difference, look at the wheels. If they are 5 or 6 lug, it is a C10. If it is an 8-lug, it is a C20. I believe...
The cab will fit, yes.
GO RANGERS grin
Photos Updated so check them out!
#108485 03/31/2005 12:07 AM
PJ
Offline
C20 is a 3/4 ton?
#108486 03/31/2005 5:34 AM
Anonymous
Unregistered
Anonymous
Unregistered
yes
#108487 04/03/2005 9:53 PM
Virtually every part from '64-'66 are interchangeable. The cab from a '64 will bolt directly in the place of a '66, regardless of the wheelbase (long wheel base or short wheel base) or bed style (fleetside or stepside). Along with the bolt pattern/number of lugs, the VIN number on the top of the driver's door pillar will indicate whether the truck is a factory C-10 (1/2 ton) or C-20 (3/4 ton). If the VIN starts with C1546 it is a conventional cab (C), 1/2 ton (1), long wheel base (5), fleetside bed (4), 1966 (6). If the VIN starts with C2546 it is a conventional cab (C), 3/4 ton (2), long wheel base (5), fleetside bed (4), 1966 (6). If the VIN starts with a K it is a factory 4x4. I hope this helps.
