| | | Forums66 Topics128,047 Posts1,055,534 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 18 Member | | Member Joined: Aug 2004 Posts: 18 | Couple questions: New at this, keep that in mind. How do you determine the difference between a C10 & C20 I have a 65 longbed stepside, is it possible to take the cab off a 64 fleetside shortbed and it fit on the chassis correctly? Thanks, James. | | | | | Joined: Nov 2004 Posts: 328 Member | | Member Joined: Nov 2004 Posts: 328 | To tell the difference, look at the wheels. If they are 5 or 6 lug, it is a C10. If it is an 8-lug, it is a C20. I believe...
The cab will fit, yes. | | | | | Joined: Aug 2004 Posts: 18 Member | | Member Joined: Aug 2004 Posts: 18 | | | | | | | Anonymous Unregistered | | Anonymous Unregistered | | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Virtually every part from '64-'66 are interchangeable. The cab from a '64 will bolt directly in the place of a '66, regardless of the wheelbase (long wheel base or short wheel base) or bed style (fleetside or stepside). Along with the bolt pattern/number of lugs, the VIN number on the top of the driver's door pillar will indicate whether the truck is a factory C-10 (1/2 ton) or C-20 (3/4 ton). If the VIN starts with C1546 it is a conventional cab (C), 1/2 ton (1), long wheel base (5), fleetside bed (4), 1966 (6). If the VIN starts with C2546 it is a conventional cab (C), 3/4 ton (2), long wheel base (5), fleetside bed (4), 1966 (6). If the VIN starts with a K it is a factory 4x4. I hope this helps. | | |
