0 members (), 361 guests, and 6 robots.
Topics128,162
Posts1,057,042
Members48,463
So i am in the process of installing the front disc conversion and i have removed the drums and now having issues on removing the backing plate from the spindle!!! Theres 4 bolts on both sides. I have removed 3 but on both sides i cannot remove the bottom bolt closest to the cab!! I have doused it in pb blaster and am unsing my impact gun and neither one will budge. Drivers side i removed the nut but the bolt wont spin or come out, and on the passenger side wont spin and cant get the nut off.
Any suggestions would be greatly appreciated.
Before you mention it, i have the assembly manual and the shop repair manual neither in this case were much help in this case
Loving my new (old) '53 3100 5 window!
The Victor Hot Wrench is your friend. Very few bolts can resist the vigorous application of a little heat, especially since you're not planning to reinstall any of the stuff you're removing!
I looked up a victor hot wrench, and couldnt find any info?
Am i falling for a joke :-)
Oh ok a torch. I will try heat tomorrow morning. I thought there was a magically high tech heated socket wrench.
I need to market that idea!!
Thanks guys for the advice!
Gas Axe, red and green wrench, are a couple of other names for it. I'm sure there are others. Good luck with your stubborn bolts.
Brian
1955.2 3100 Truck
55shaker #1084590 02/09/2015 9:56 AM
When I worked in a junkyard we called it a smoke wrench.Most valuable and most used tool we had.---Jack
Hot wrench round chere. (we also tend to say round chere, warsh, chimley, winder [the kind what gets cleaned by the winder warsher]. But we don't ever say WOOOO Doggy!
Carl
When I lived in Albemarle County we said something like wee doggie.
well I finally got the old bolts, backing plates etc off and the new brakes on and now to move onto the power booster/master cylinder install.
Gas Pumper
Gas Pumper
Some of us opted to not go with the power booster due to the stock crossmember alterations, but if you need help with any of it, there are really knowledgeable people here to help! Good luck!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
