1 members (51sub),
128
Mod | | | Forums66 Topics128,125 Posts1,056,338 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 32 | getting no oil through hole in top of rocker arms, some oil is dripping from bottoms, is this from worn bushings or are there other causes for this? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Have you taken apart the rocker arm assembly and cleaned the shafts and rocker arms?
| | | | | Joined: Jan 2012 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2012 Posts: 32 | I soaked the assembly in gas and kerosene when I changed the head gasket. when I plug the oil return tube oil will come out of the top holes | | |
