0 members (),
135
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 38 | I bought one of those 6 volt to 12 volt resistor thingee for the gas gauge from Classic Parts. It is spliced into the hot wire going to the gas gauge. No matter how I connect wires the gauge always reads to the full mark when the ignition is turned on. What did I do wrong????? ken | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Something is not grounded.
Try running a wire from a clean/good ground to a sender attachment "screw" at the tank (to see if a ground is the problem). I sometimes run a "test" wire from a sender attachment screw all the way back to the ground terminal on your battery (negative terminal for a Chevrolet; positive terminal for a GMC).
| | | | | Joined: Nov 2013 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 38 | tcelderman, That did not change anything. I ran a wire from one of the attachment screws directly to the frame. Ground a shiny place on the frame to get good contact. Still, when the key is turned on it registered "FULL". Any more ideas???? The taken has about 7 gallons in it. Its a 48 with the tank under the bed. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I am a simple-minded numbskull when in comes to diagnosing gas gauges.
Run a wire from the sender post on the gas dash-gauge to the sender wire post on sender unit on the gas tank.
If you still read full, my guess would be a bad fuel gauge.
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Did you happen repaint the backside of the gauge cluster housing? You need some clean, shiny metal where the gas gauge touches the housing. Carl
