| | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | Well, my '49 cab need A LOT of metal replaced. Door bottoms, inner & outer cowls, cab corners, etc. I have all the patch panels I need here already. I have a MIG welder also. I'm a proficient welder, but I've never done sheetmetal before. The lightest stuff I've ever welded is exhaust pipe. Is there an online resource or anything that gives the do's and don'ts of sheetmetal welding? Can anyone offer any advice on how not to screw this up?? Thanks in advance.
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | | | | Joined: Apr 2003 Posts: 22 New Guy | | New Guy Joined: Apr 2003 Posts: 22 | The biggest thing I've learned with sheet metal, which you probably are not used to is you can't just weld a continuos bead. The sheet metal will warp badly if you try this. The best thing to do is to tack the the panel in several places around the panel and not weld in anyone place with out allowing the metal to cool. A wet rag can help cool the metal if you are in a hurry. Just keep tacking the panel until you end up with a continous bead. Granted it won't be the good looking beads you are used to, but you are going to grind them down anyway. Remember though you also need to move the grinder around and not cause too much heat as well or you will warp the panel. Where in Western, NY are you located? I live in Williamson, NY ~ 25 miles east of Rochester. Good luck with your project.
Jim
| | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Before I started to weld anything I bought some cheap metal and practiced until I could weld without burning holes in the metal. Jim is correct, you should weld short beads to avoid warpage. Good luck.
ed | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Southtowns27, I would do a real good search on this site before I did anything. I was going to do floor, toeboards, inner and outer cowl etc on my 55/1st, and after reading about poor fitting reproduction parts, cabs that tweaked and just general pain in the rear end stuff, I found a rust free cab, thank the stovebolt Gods! Many procedures you need to go through are actually documented with how to pics available right here on this site...DO THE SEARCH! Stuart. | | | | | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | I have a friend who was a professional body man before he retired, and he usually does my welding for me. When he is replacing a panel he usually crimps both sides with an air crimper, so that he creates a smooth lap joint, punches small holes in the crimp on the outside piece and then welds those shut. As a rule, he doesn't try to make a continuous bead on the joint. He has done some really nice body work for me, and I think he does know what he is doing. I have a MIG welder which seems to do a nice job on sheet metal. Allen | | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Bakerallen, I have the flange tool that you are speaking about, one side flanges the panel and the other side punched the holes so you can tack the panel in place. It is recommended that you completely weld up both sides of the lapjoint or a possible rust problem will develope. Some times you can not get at both sides so you maybe only able to weld one side. If possible seam seal the other side to prevent moisture from getting inside the joint. Remember those Japanese trucks from the 80's where the beds rusted in half on a horizontal line running down the entire bed side? This was due to the two piece bed side s being lapjointed and only spotwelded. Had they welded both sides completly the beds would have lasted a lot longer.
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
