8 members (Wickedbass, tclederman, Rusty Heaps, Peggy M, TexasA&M48Truck, Wally / Montana, Gray_Ghost, UtahYork),
115
Mod | | | Forums66 Topics128,066 Posts1,055,876 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 125 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 125 | I have a broken top leaf on the front of my 3100. Are there any special tools that I need take the spring out of the truck ?
Stan | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy StanT, no "special" tools that I can think of, if you support the frame on stands and undo the U bolts and let the axle drop down away from the spring a bit, you should be able to remove the shackle and pivot bolt and remove the spring. Hope that helps. | | | | | Joined: Feb 2014 Posts: 125 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 125 | Thanks 3B. Ive got heavy duty stands and such. Ill get it out and take the spring up to an outfit in Ladysmith to get it repaired.
Stan | | |
