0 members (), 80 guests, and 4 robots.
Topics128,062
Posts1,055,857
Members48,428
I have a broken top leaf on the front of my 3100. Are there any special tools that I need take the spring out of the truck ?
Stan
3B Offline
Hy StanT, no "special" tools that I can think of, if you support the frame on stands and undo the U bolts and let the axle drop down away from the spring a bit, you should be able to remove the shackle and pivot bolt and remove the spring. Hope that helps.
Thanks 3B. Ive got heavy duty stands and such. Ill get it out and take the spring up to an outfit in Ladysmith to get it repaired.
Stan
