4 members (Brian Moore, walter74, J Lucas, Jims46), 62 guests, and 3 robots.
Topics128,030
Posts1,055,423
Members48,422
#108338 11/12/2002 8:26 PM
Working under the dash of a 50' 3600. Getting ready to clean and paint under there. Question is.... What do I paint it with and what color?? Thinking about tan Zero-Rust. What was stock?? I'm thinking wire brush, steel wool and the ZR, but I'd love you'alls thoughts
#108339 11/12/2002 10:38 PM
The only paint under my dash was overspray from when the painted the dash. Clear up underneath the dash had no paint at all, just bare metal. cool
#108340 11/13/2002 3:05 PM
I painted my with ZR in white. That way I can see what I am doing. Dark colors will make it difficult to work under there.
Fritz Peyerl
Turner valley, Alberta
http://www.badmileage.com
#108341 11/13/2002 4:55 PM
if it's rusted at all under there I would POR-15 (por stands for paint over rust) would be better then zero rust which likes clean bare metal better.
May the force be with you - SoloWookie
solowookie.com
#108342 11/14/2002 6:22 PM
I thought "POR" stood for that fact the you are poor after buying the stuff!
1951 1 Ton Completed
#108343 11/14/2002 6:39 PM
Zero Rust works better on a slightly rusted surface for bite. Not clean metal. Just remove all loose material and encapsulate.
54 3100 with 235
62 flatbed dump C60 with 261
#108344 11/14/2002 7:01 PM
Gentlemen:
One of Zero Rust's real benefits is that it can be used on BOTH clean bare metal AND on less than a white metal blasted surface! We all know that the latter is the ideal, but more often than not it just ain't practical or possible to get there.
As long as you remove any loose or flaky rust (which entraps oxygen and therefore rust will likely continue) you can then apply ZR and be assured that maximum adhesion will result.
I would advocate use of our Prep-Step as an added precaution to making sure that the metal is free of greases and any other contaminants that will interfere with paint adhesion - regardless of what kind of paint you use.
HTH
WK Irish
#108345 11/14/2002 9:40 PM
Thanks for the replies. Under my dash looked like it had never ben painted also. I will use the tan ZR, white is Too bright and I think that the tan will be okay when I repaint the exterior of the dash etc.
#108346 11/15/2002 5:08 PM
well - thanks, but I'd still go POR if painting over rust, and ZR to clean metal. I believe that's the strengths of the 2 products.
solowookie.com
#108347 11/18/2002 6:58 PM
Solo my friend you've been given some bum information. ZR is as good as any surface it is shot onto.
If the rust is scaley loose, ZR will fall of "with the scale" and you won't get it off the scale.
It is the perfect product to use where you have tight rust and shiney or not so shiney metal on the same surface.
ZR is a sealer ... POR is a converter which chemically converts rust to something akin to porcelain ... it does not work on shiney metal ... nothing to convert.
Get Bruce Palmer to send you a brochure - it lays it out nicely.
#108348 11/19/2002 6:22 AM
Anonymous
Unregistered
Anonymous
Unregistered
Anything you spray under the dash is better than the factory nothing . Which after 50 years now is surface rust.
