2 members (Hotrod Lincoln, homer52), 93 guests, and 0 robots.
Topics128,049
Posts1,055,638
#1083388 02/03/2015 3:47 PM
7
7 Offline
I have asked many people with no answer.
What is the open slot on the column just above my steering box, it has a metal cover over it. I have a 1950 216 Chevrolet pickup.
1950 Chevrolet 1300 - Canadian Built
This truck is now for sale (9/2016)
All Original
More pix in Bolt Bucket
Thats where the wire is fed for the mast bearing right behind the steering wheel, the wire provides power to the horn button
1950 Chevy 3800
4-53T Detroit Diesel conversion
More pictures in Photobucket
I believe the slot you are referring to is for locating the column shifter box which has a small boss on the back side. If you have a floor shift the slot has no purpose.
You Tube
7
7 Offline
Thanks that makes sense. The horn wire is much higher. Thanks again.
All Original
