5 members (2-Ton, Peggy M, Bill Hanlon, Woodcmiami, 1 invisible), 164 guests, and 2 robots.
Topics128,167
Posts1,057,015
Members48,458
A friend of mine has recently aquired a '48 GMC 1/2 ton pick-up.
To be honest my knowledge of these trucks dashboards is somewhat limited.
He is planning some upgrades one of which is to fit an after market speedometer either mechanical or electronic and other gauges as the truck came without any at all.
He'll be going down the V8 route.
Are there any vendors who sell retro-fit 12v gauges with modern internals and don't require adapters?
Thanks in advance.
More pix on Flickr.
The gauges in '47-53 New Design trucks are the same diameter as in Advance Design trucks of the same years. There are several aftermarket suppliers.
Just remember, there are two different mounting patterns on
the back of the gauge where it mounts to the dash studs. The
GMC (floor shift) is not a square pattern. Been down this road.
Good luck and measure your mountings before ordering!
1947 GMC Truck 5 window, Long Bed
2008 Corvette Roadster
2008 Harley Davidson FXDL
2011 F150 Ecoboost 4X4
2015 Subaru Outback AWD
"only the strong survive"
I forgot about that. I think it only applies to '47s. The studs were moved when they went to column shift.
These guys will update his core
Even add a tach
http://speedometershop.com/enc-pag.htm
Mucho dinero
Thank you Gents,I had it in my head they were quite different.
More pix on Flickr.
Neverdone
Unregistered
Neverdone
Unregistered
Thanks in advance.
Jockbolter , I built a couple of welding tables for these guys in Boyne City Michigan , they have one heck of an operation and will put modern electronics into your gauges if you send them to them . I am not sure about the ''RETRO "" part but you could always re-decal yours before you send them out ...they are not inexpensive though everything is relative . I have seen their factory and their work ..impressive
They can do any gauge type
http://www.classicinstruments.com/
Dan
He could go high tech with Dakota Digital.
Thanks again fellas,i've passed this info onto my friend,i'll let him decide.
More pix on Flickr.
