8 members (55shaker, Bruce 1954-4100, Hanks custodian, Gdads51, BC59, Cletus1950, cmayna, 3800GUY), 126 guests, and 1 robot.
Topics128,109
Posts1,056,253
Members48,437
#1082270 01/29/2015 4:23 PM
The 1952 216 runs like a dream for about ten minutes and then the points come out of adjustment. I set back to roughly .020 and it runs great, then slips again. Every time I check it to readjust, the screw is still tight but it's out of adjustment. I am thinking the bracket underneath is slipping but I'm not totally sure.
Anyone else experience this or have a remedy?
Thanks!
First thing I would look at is the screw holding the points in,and then the threads in the hole to which the screw goes into.....
either one of them could be stripped or missing a thread and the screw won,t hold.
steve sr.
If the gap is getting closer, look at the rubbing block. I'll bet it's wearing due to a rough spot on the cam.
Ex Hall Monitor
Ex Hall Monitor
To build on Jerry's reply a bit you do have the cam lubricated adequately??? An unlubed rubbing block will close the point gap in a hurry.
I have not lubed it since I purchased. What kind of lube goes on there?
Use a very light coat of high temperature grease, LIKE "disc brake" wheel bearing grease. a little goes a long way, but it MUST be there. Some good-quality point sets come with a small capsule of lube in the package with the points.
Ever see a set of points with no rubbing block? That is why. It is a cam and the rubbing block is the lifter. You can polish the rough spots with some 1000 grit paper. It won't change the shape unless you go crazy with it. Just smooth to the touch is good. I put a little grease on my finger, rub it with my thumb. Take most off the finger and thumb with a paper towel. And rub the finger and thumb on the cam. That is all it takes.
Steve H
Thanks, fellas. I will get some grease on there and check that there aren't any rough spots on the cam before firing it up again.
Ex Hall Monitor
Ex Hall Monitor
I use assembly lube. It's lightweight and VERY slippery.
