3 members (Steelonsteel, Patina 54, CandoBrent), 42 guests, and 3 robots.
Topics128,034
Posts1,055,440
Members48,422
#108181 02/01/2002 12:41 AM
I have a 51 chevy and the rear fender support rods have vanished in the dissassembly. What I need to know is HOW LONG ARE THEY? Can someone measure theirs and let me know. They are the ones on the back end of the fender. Do they bolt to (fender to box) or (fender to frame)? Thanks.
[ 01-31-2002: Message edited by: shidoshi51 ]
#108182 02/02/2002 1:30 AM
I can tell you they run from the bottom of the frame to the back of the rear fender. I'll have to check mine tomorrow and let you know length. smile
#108183 02/03/2002 2:26 AM
Measured my rod up today. The overall length is 12 1/2" long. The rod is 3/8" in diameter with each end flattened for 7/8". Ends need to be flattened on oppisite sides, then have a 5/16" hole drilled in them. You can probably locate hole on one end after you try it on your truck. Hope this helps. Ends need to be angled. smile smile
#108184 02/03/2002 3:48 AM
I was missing my front fender brace and got it from mothertrucker in AZ. He posts on this forum.
54 3100 with 235
62 flatbed dump C60 with 261
