1 members (Guitplayer),
48
Mod | | | Forums66 Topics128,035 Posts1,055,447 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 7 Member | | Member Joined: Jan 2002 Posts: 7 | I have a 51 chevy and the rear fender support rods have vanished in the dissassembly. What I need to know is HOW LONG ARE THEY? Can someone measure theirs and let me know. They are the ones on the back end of the fender. Do they bolt to (fender to box) or (fender to frame)? Thanks.
[ 01-31-2002: Message edited by: shidoshi51 ] | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I can tell you they run from the bottom of the frame to the back of the rear fender. I'll have to check mine tomorrow and let you know length.  | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Measured my rod up today. The overall length is 12 1/2" long. The rod is 3/8" in diameter with each end flattened for 7/8". Ends need to be flattened on oppisite sides, then have a 5/16" hole drilled in them. You can probably locate hole on one end after you try it on your truck. Hope this helps. Ends need to be angled.  | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I was missing my front fender brace and got it from mothertrucker in AZ. He posts on this forum.
54 3100 with 235 62 flatbed dump C60 with 261
