0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I need to replace all 60 of the X mounted extension springs that connect the coil springs together in my 1956 seat bottom. Does anyone have a source for these small springs? What are they called? They don't have hooks on the ends they just attach to the coil spring by corkscrewing around a turn or two. Thanks, Mike B  | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And how will you replace them Mike? I would think there has to be a special wrapping tool to install them.
Denny G
Denny G Sandwich, IL
| | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Wouldn't it be easier to find a solid seat bottom?
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
| | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | check McMaster-Carr, they have a wide variety of hardware. Mike | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Denny, the springs are easy to remove and replace, no special tools needed. I just want to replace all of the little springs as most of what I have are rusty and I thought it might help firm the seat up. ctheusa, good solid seats are hard to find in the Mid-Atlantic area. What I have is very solid, I have about 10-12 broken little springs (not the big coil springs) and figured I'd replace them all while I have the seat apart. bluedot38, Thanks for the suggestion, I'll check them out! Mike B  | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I ordered "cut to length" springs from McMaster-Carr yesterday and they showed up today...that's fast service. They look like they will work. Thanks everyone, Mike B  | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Glad to hear that, and to be a help, along with the others
Mike | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Now ya gotta put some pictures up of that re-do Mike. Still wondering how you're gonna put that wrap around the main spring.
dg
| | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Agreed- thought it was the large verticle springs deformed. Sounds doable now. (Need to read better)
ctheusa, "good solid seats are hard to find in the Mid-Atlantic area. What I have is very solid, I have about 10-12 broken little springs (not the big coil springs) and figured I'd replace them all while I have the seat apart."
