5 members (Woogeroo, klhansen, 2-Ton, TUTS 59, 51sub), 82 guests, and 7 robots.
Topics128,193
Posts1,057,241
Members48,465
I have a broken stud on the front wheel of my truck.DO i grind off the rivets to get the drum off and punch it out like all the other (vehickles) i have done it on or is there something i do not know since i never did this kind of truck. THANKS for any feedback. BJF
You do not need to grind the rivets unless you need to replace the drum. I don't know just how much experience you have with the old style packable bearings, but taking them apart is going to be the easy way to do it. Here's the manual page that explains the procedure. Once you have the drum/hub removed, you can drive out and install the new one just like you would on a late model vehicle.
Bill Burmeister
THANKS FOR THE INFO BJF
If you don't have one, this tool makes putting the new stud in very easy.
Bill Burmeister
Riding in the Passing Lane
You can do the same with a stack of washers.
1972 Chevy c10 Cheyenne Super
Use a deep socket that will slip over the stud and a big C clamp after removing the brake drum from the hub. Tighten the clamp firmly, then smack the end of the clamp screw with as BFH. Repeat as necessary until the stud seats itself against the hub. If you try to pull the stud in with a lug nut, you'll stretch or break the new stud. You can also support the hub over a set of vise jaws gapped open just enough for the stud to go between them and and drive the stud into place with a BFH and a piece of soft steel round stock.
V
V Offline
Love it! Repeat as necessary..LOL
