| | | Forums66 Topics128,022 Posts1,055,362 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | Hey folks I got a can of engine paint (Dupli Color Engine Enamel with ceramic) that i really like the colour of. Is it okay to use this on the interior (dash, floor, doors)? will it hold up well? Thanks!
1948 3600 thriftmaster
| | | | | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | ought to last better than it would on the engine! | | | | | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | yeah, i figure it should. but will it last better than regular base clear?
| | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | As long as you are going to have to do the same amount of work for prep(sanding, masking, etc.), why not just shoot the base/clear. You will get a much nicer paint job than you will using the rattle can stuff. You should be able to get a close match to the rattle can color from your local paint supplier.
Just my 2 cents. | | | | | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | thanks bigbassman, the reason I ask is because the rattle can stuff will cost about $20, while the base clear will cost $200.
| | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | Gecko,
Think how much more it will cost to do it again, and again. If you use the rattle can, you will need to repeat, as it will not hold up as well.
Bite the bullet and do it right. Nobody says "I wish I had done the elcheapo job..." when it looks good and lasts a long time. The other is certain to have regrets.
Make a good looking truck into a great looking truck and you won't regret it. | | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | One more thought, if base clear is too spendy, consider a good single stage. I'm thinking of using PPG's DCC for mine. That will save the cost of the clear.
Good Luck!!! | | | | | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | jake53 thats exactly what i was looking for. my original question was wether the rattle can engine paint would hold up well. the cost is secondary to durrability. thanks again
| | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | That's why we all come here. Sometimes we have a good idea that we should share with others, and other times we get better ideas back. It's a collective inteligence issue. Hundreds of minds together lead to smarter moves.
Best of luck! | | | | | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | ya go with singal stage fast easy and cheap one gallon will do your truck in and out for 100. or less | | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | I'm not too sure on the 100 bucks stuff, but you can do a very nice job with it. | | | | | Joined: Jul 2004 Posts: 102 Member | | Member Joined: Jul 2004 Posts: 102 | okay, i think i'll use the single stage for the interior. the outside of the truck i will do with base clear for sure. thanks for the help fellas
