6 members (Hotrod Lincoln, klhansen, Mike B, Otto Skorzeny, IHPWR, Jims46), 50 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
#108074 08/24/2004 12:32 AM
Hey folks
I got a can of engine paint (Dupli Color Engine Enamel with ceramic) that i really like the colour of. Is it okay to use this on the interior (dash, floor, doors)? will it hold up well?
Thanks!
1948 3600 thriftmaster
ought to last better than it would on the engine!
yeah, i figure it should. but will it last better than regular base clear?
As long as you are going to have to do the same amount of work for prep(sanding, masking, etc.), why not just shoot the base/clear. You will get a much nicer paint job than you will using the rattle can stuff. You should be able to get a close match to the rattle can color from your local paint supplier.
Just my 2 cents.
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
thanks bigbassman, the reason I ask is because the rattle can stuff will cost about $20, while the base clear will cost $200.
#108079 08/26/2004 10:35 PM
Gecko,
Think how much more it will cost to do it again, and again. If you use the rattle can, you will need to repeat, as it will not hold up as well.
Bite the bullet and do it right. Nobody says "I wish I had done the elcheapo job..." when it looks good and lasts a long time. The other is certain to have regrets.
Make a good looking truck into a great looking truck and you won't regret it.
#108080 08/26/2004 10:36 PM
One more thought, if base clear is too spendy, consider a good single stage. I'm thinking of using PPG's DCC for mine. That will save the cost of the clear.
Good Luck!!!
#108081 08/26/2004 11:44 PM
jake53
thats exactly what i was looking for. my original question was wether the rattle can engine paint would hold up well. the cost is secondary to durrability.
thanks again
That's why we all come here. Sometimes we have a good idea that we should share with others, and other times we get better ideas back. It's a collective inteligence issue. Hundreds of minds together lead to smarter moves.
Best of luck!
ya go with singal stage fast easy and cheap one gallon will do your truck in and out for 100. or less
I'm not too sure on the 100 bucks stuff, but you can do a very nice job with it.
okay, i think i'll use the single stage for the interior. the outside of the truck i will do with base clear for sure.
thanks for the help fellas
