11 members (Eisenholtz, Gone, Peggy M, Donf, Otto Skorzeny, Wickedbass, Hawkman, NJC, GRNHydra, hdgeren, 1 invisible), 72 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
Got a Delco 1116522 replacement switch for my 1959 Apache. They are advertised as replacement for 1959. Discovered that switch contacts do not match; triple connector will not fit replacement switch. Old switch has a 522 on casting and the contacts do match the 1959 wiring diagram. Traced new switch, when on: BAT connects to IGN-1/ACC; START connects to IGN-2. Anybody experienced this problem? Any ideas on whether and how to use?
Thanks!
see similar new switch contacts: http://www.ebay.com/itm/NOS-Ignitio...ries&hash=item43d24f5eac&vxp=mtr
1959 Chevy Apache Short Bed Step Side
1967 Cadillac DeVille Convertible
1967 Pontiac Firebird Convertible
3 position switch
- all forward control trucks
- all automatic transmission trucks
- all 8-cylinder engine trucks
2 position switch - all others
http://chevy.oldcarmanualproject.com/chevyresto/59ted21.htm
Thanks, guys. Makes sense....mine should be a three-position; looks like I got a got a NOS two-position.
Sir Searchalot
Sir Searchalot
After looking again, I think you are correct. So if you need the "V8" switch, they are available new. The 2 pos is not and should be quite saleable especially NOS.
