4 members (Wayne67vert, Phak1, Peggy M, WICruiser), 127 guests, and 4 robots.
Topics128,111
Posts1,056,243
Members48,437
#1079687 01/17/2015 3:07 AM
I have a 59 3800. With a stock fuse box. It has posts for radio, heater, some lights, and then a few posts that aren't marked. Or have lost there markings does anybody know what posts are hot when the ignition switch is off? I know the cig lighter, and horn are always hot. But no fuses for them. I want to plug my radio wire into the fuse box. Not the radio hot wire but the wire you use to keep the preset station and clock I'm trying to avoid hooking the wire to the POS on the battery
Your "stock" fuse box would actually be an accessory fuse box. It and radios and heaters were dealer installed accessories in those days.
As far as what terminals are hot and when, a multimeter will tell you.
not totally clear, but labels here, and usually the top tab on the main strip [left side] is the power connection - but as Cletis says, a meter is the best check
I am begging you, please add an inline fuse to the cig lighter! If you do this, you and I can sleep better at night (which is the most likely time of day for a rodent to gnaw on your wires).
Carl
Because I care.
panman and Carl - there is indeed a fuse on the panel for the accessory lighter - it's the one labeled "ACC"
Before Mrs. Wally became Mrs. Wally, we were sitting in my '51 Chevy Deluxe watching the submarine races. The lighter started smoking and glowing red hot from under the dash. I quickly pulled off the wire and burned my hand. I don't know how that was fused but I have removed the lighter wire from my '48.
Pictures of the '51 are in the link shown in my signature.
The '58 Shop Manual wiring diagram appears to show the cigar lighter wired to the ignition switch hot side with no fuse.
Sir Searchalot
Sir Searchalot
Wally, have not heard that in 50 years. Submarine races, brings back memories.
Old trucks may or may not have a fuse panel. Bottom line: Everything needs to be fused. I add fusible links on major feed lines from battery also. I also recommend a Voltmeter not an ammeter, for safety. Carl and I are in the same paranoid group therapy program at the hospital via skipe.
"I disconnect my battery at night on old trucks." There, I've said it.
that's shown in all the TF diagrams from 55.2, but note that it's shown as a dotted line, meaning it's an accessory, same as the optional electric wipers also shown with no fuse - the TF years only got a fuse panel [also on the diagrams w/ dotted lines] if there were a number of optional accessories installed from new
Been there done that (except for, that I am pretty sure that it wasn't with "Mrs. Wally before she was Mrs. Wally, nor after she became Mrs. Wally", for that matter. smile ).
Molten copper leaves a bad mark on the ole mitts.
Carl
