| | | Forums66 Topics128,194 Posts1,057,263 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 13 New Guy | | New Guy Joined: Sep 2014 Posts: 13 | Trying to gather tools im going to need to restomod an old truck. What is the best type of welder to use if I need to do frame and probably some body work?
Is mig or stick he preferred method to weld a frame together? I know mig are used for body panels.
I do know it would need to be 220v. I'll be running 220 to my garage for an air compressor and welder. | | | | | Joined: Dec 2014 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 55 | I prefer a stick welder myself,but I was raised by a pack of anal retentive railroad blacksmiths/boilermakers. eastwood makes a stitch welder for use with stick welders. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I asked this same question probably right here about 13 years ago. I went with a Lincoln SP-175+ 220 Mig welder. It was, and IS the perfect thing. Nowadays, you might want to get the new model, either a Lincoln 180 or a Miller 180. Wire feed Mig welders will do everything you need, altho I still want a TIG just to learn to use it. Good luck!
| | | | | Joined: Mar 2010 Posts: 10,308 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,308 | Devey boy, long time no see. Lay out the cash for the TIG. With all of the MacGyvering which you do, you will never look back. You can do amazing things with a TIG. Carl
| | | | | Joined: Feb 2012 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 96 | if you get a big enough one a mig will do it just fine you have to look at duty cycle for the given thickness or you could do it all with a tig, just needs to be big enough. tig is really nice for body work | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | I started stick welding over 50 years ago. I bought my first wire welder over 30 years ago and I hardly ever use stick at all. I have Millermatics from 200 to 252 and a wire feeder that hooks on to my Trailblazer 440 with .045 flux wire for outdoors welding. I have welded a lot of air ride suspensions to 25,000 axles with it.
At home I have a Hobart 140 that runs on 110, and there is nothing on a pickup that I can't weld with it including the frame.
I have a Miller Dynasty 350 with a water cooled gun at the shop that no one really uses because it is too slow. It makes a nice weld on aluminum, but I can weld circles around it with wire. The factory in Lincoln, NE, Cornhusker 800, which builds our trailer doesn't even own a tig. They do everything with wire.
| | | | | Joined: Sep 2013 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 61 | I second the TIG vote. Definitely slower but it's so darn nice to use. I've got a small portable Miller unit that does both TIG and stick.
Whenever you leave behind failure that means you're doing better if you think everything you've done has been great you're probably dumb -Louis CK- '53 GMC | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Mig will give you the best mix.
Tig has a high learning curve and needs expensive tips and gas. Stick really doesn't work will with thin sheet but will work on rusty/thick steel.
FCAW on a 110V unit can do 1/2in steel. GMAW can so 20 gauge with clean beads.
OA can cut, and do thin metal, but acetylene is expensive and you gotta learn how to work the weld puddle.. and overhead beads with OA are not for beginners.
FCAW Mig needs no gas and go thick (like Stick) GMAW needs gas but can go thin (like Tig) and is MUCH faster.
Last is cost:
Stick welder: $300 or so. MIG: $300 or so TiG: not less than $500-1000 OA: $100 for a HF set (yes, they are highly rated and even my local welding supply recommended them) but you'll need tanks. If you buy tanks add about $400-600 for a 240cu/ft O2 and 80Cu/ft Acetylene | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | My opinion and that of my College welding instructor, Get Both. If you want structural safety-stick. Most everything else-MIG, that means with gas. A 220V Compressor and a stick welder usually do not operate on the same circuit. One is 30A, one is 50A. I often wish I had a Plasma Cutter but I do pretty well with an angle grinder and die grinder. (I often wish I had a Corvette too but get by with a Truck or two.) I have a 220V compressor, a 220V Arc welder and a 110V MIG. The 110V MIG allows fixing things all around the house/yard/ranch and I can take to a family members home to fix things there too.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2010 Posts: 10,308 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,308 | Bart, on a side note. If I live on 1/4 acre, own 2 cats and two dogs, and one of the dogs is a herding breed, can I confidently refer to my spread as a ranch? I do have a "house/yard". Just wondered what the rules are for the "ranch" part.  Carl Rancher wantabe
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | 52Wanabe: Don't know. I don't have that either. Was trying to say that 110V is good for moving about small or large home areas because of plug in availability. Around the home or yard or even a ranch. If you had a ranch animal maybe you could be a ranch... or mini ranch
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | If money is not a concern then yes, both a stick and MIG, but the only place stick will beat a MIG outright is that stick can weld rusty metal and much thicker. Some say that stick is better if there is a stiff wind.
Mig FCAW needs some surface prep... both will have slag to clean up. I don't know of any frames that are 1/2in steel. Most are 3/8ths or less, some maybe 5/16ths. My 2.5 ton is 5/16ths.
The real benefit to Mig is that will do thick, but also thin. .020 tips and wire with gas will 20gauge nicely. I'm not sure stick will to that without lots of experience and proper setup. Mig is easy, set the dial and press the button.
Lots of structural steel is Mig'd. A stick only lasts so long, Mig can go as long as there is wire on the spool (a few hundred feet) and the transformer is kept cool. Stick does have an advantage in that there are many, many types of rods for just about every need. But plain ol steel.. forget the stick and with the money you saved buy a good welding cart.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The Lincoln OR Miller 180 wire feed migs come with 2 plugs. One for 110, the other for 220. Of course you can weld hotter and deeper with 220. Great for what we do. Get a nice helmet with magnifiers while your wife lets you hold the credit card.  | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | The $50 HF auto dark helmets are very good buys and highly rated. Mine is 4 years old and works great.
Most new welders forget that they still need plenty of light. The arc alone is not enough. Get a good halogen light on a stand and use it... it will help you see before the ark is struck (the helmets are still kinda dark even before they activate) and you will be able to see your lines/seam much better.
Bonus that the auto dark helmet will activate if you accidentally look at the halogen light. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Agree about HF Helmet. Mine is 8 yrs old. Just have to replace batteries sometimes.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Me three on the HF Helmet. However, there is a better one out now. I needed to eliminate that damnable Halogen light. It was just a pain to drag around all over the place, so I looked and noticed that Lincoln makes a Viking 3 series helmet that lets you dial down the shade number clear down to 6. The problem I was having was, the lowest setting (9) was just a TAD too dark causing me to go for the halogen. When its set on 8, woohoo! I can see again! I think the eye calibrator didnt have his machine working that day or something cause 8 works perfect for me.
Add to that the magnifier lenses available for it and I have never had such an enjoyable experience welding. They arent cheap though. | | |
