7 members (Otto Skorzeny, Gdads51, VEW, MickeyP, 50Chevy3100, HandyAndy, 1 invisible), 74 guests, and 1 robot.
Topics128,090
Posts1,056,015
Members48,430
#1078457 01/10/2015 8:12 PM
Any one have source for repop running boards and bed for the 3600. Tjese are longer than the easy find 3100.
Check with Mar-K for the bed.
bought mine from mar-k
good instructions and it went together perfect!
1963 c10
Running boards? Good luck. If you find a good set of used ones snatch them up.
Most end up cutting and welding 1/2 ton boards together to get the proper length.
Superior Glass Works lists them for 3/4 ton truck. Might be worth a call if you don't care if they're glass.
http://www.superiorglassworks.com/Running-Boards-Smooth-1947-1954-Chevy-Truck-p/53t04.htm
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
I've occasionally seen them come up on e-Bay. You might want to search under GMC as well as they had the longer running boards on a 1/2 ton long bed option as well as the 3/4 ton. And I would put and ad here under the parts wanted.
Mike
I just had to delete a part offer and a response to it. Parts offers, parts wanted, buying nor selling are not allowed in General Truck Talk. Such business should be conducted by PM.
We have a Swap Meet section specifically for buying and selling.
