Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
7 members (JasonP, Peggy M, JW51, TooMany2count, Ponchogl, 32vsnake, Gib70), 565 guests, and 1 robot.
Topics126,778
Posts1,039,291
Members48,100
Most Online2,175
Jul 21st, 2025
#1078497 01/10/2015 11:48 PM
Looking for some electrical Help. I am trying to install Autoloc Momentary Switches to power my windows. The Switches are Keep It Clean 19MM Momentary Billet Buttons with LED Rings and using the associated Plug and Play Harness. The Relays are The Speedway Engineering Relays and Harnesses. Bosch type Relay. 30/40 amp.
The Power Windows work when wired, without relays, using a standard power window switch. No issues.
When I wire the Windows with the momentary switches, as defined by Keep it Clean / Autoloc, the LED activates and I hear the relay click, and I get 12V to one of the circuits to the power window motor - but I appear to have a problem with the return ground - and I have no idea how to overcome this problem. I know it’s the ground - because I can get a button to work if I jury-rig it with the old power window 5 lead switches on the “return leg” as this provides me the ground I appear to be missing.
I have follow and retraced stepsIn the Autoloc diagram - I have the same behavior with all 4 switches.
The only thing I am doing different than the Autoloc Diagram is the 87a ground. I can’t ground 87a, as it gets power when I activate the switch (as it should, I believe) and causes a short that fries the fuse.
I put a meter on the relay and here is what I found - without activating the switches. 85, 86 and 87 are all hot. 30 and 87a are not. When I activate the switches, 30 and 87a then are hot.
Thoughts and ideas where to go would be great
Clark VB #1078675 01/11/2015 8:28 PM
Look at this site. Scroll past the pictures of what is inside, and you will find a Hook up diagram. According to the diagram, 86 is ground. 85 is from the switch. 87a is normal closed. And 87 is normal open. 30 is power to the relay. I hope this helps. It would appear that the issue is 86 not to be power, it is the ground. Could just be a misprint in the instruction sheet. Let us know how it goes.
Steve H
Clark VB #1079008 01/13/2015 8:33 AM
Missing link:
http://www.bcae1.com/relays.htm
Original has left the building
Steve H
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.590s Queries: 14 (0.026s) Memory: 0.5985 MB (Peak: 0.6360 MB) Data Comp: Zlib Server Time: 2025-09-22 18:19:42 UTC
Valid HTML 5 and Valid CSS
