3 members (Wayne67vert, Otto Skorzeny, stlcardinalsguy), 66 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#1078448 01/10/2015 7:18 PM
A while back i got instructions on how to seperate the tail section from the trans. Just started it this am and found snap ring but no way to put snap ring pliers on it. usually have two raised portions at ends to pull together,this does not.Ideas on how to get snap ring off??
Midpiner #1078451 01/10/2015 7:41 PM
The snap ring on the rear bearing needs to be expanded to remove the bearing and tail shaft.
My Blog
Midpiner #1078464 01/10/2015 8:43 PM
And how do i expand it? I see nothing to grab it with? No holes in the snap ring.
Midpiner #1078466 01/10/2015 8:52 PM
Are you saying rear bearing(drive shaft end) or front(gear box end)
Midpiner #1078469 01/10/2015 9:04 PM
If the end tabs have broken off the ring might have rotated the gap away from the access hole. Try using a sharpened small file to pry the ring around until the ends appear in the hole, then use a pair of expanding snap ring pliers to stretch it out and pull the bearing through the ring.
Midpiner #1078475 01/10/2015 9:31 PM
Will try. I had turned the snap ring 360 degrees hoping a tab might appear. Thanks for your help
