5 members (frogfarmer, Youngin' Tut 59, Phak1, jay d, 1 invisible), 72 guests, and 2 robots.
Topics128,196
Posts1,057,390
Members48,469
This truck is tagged titled and insured. But shes not road ready.
I need some direction or a shove hahaha... you guys help with getting my plan on track..
So i have a couple projects. I work on one till i hit a roadblock which i trt to go around under etc. This is my clutch problem. Without motor on -my i can put her in gear ir out. But cannot shift while shes running.
I brought this up before briefly. Then jumped to the 1930dirt in the nackground and then the blue 235. Im flipping between the three due to caah available or roadblock etc.
I have service manuals etc.
I think the consense was to unbolt rearend. Pull it bqck aling with tranny to access clutch. What should the pressure plate clutch NOT LOOK like when i get to that point. If i have
1938 Chevy 1/2 ton Pickup
1940 Chevy 3/4 KD Pickup
1946 Chevy 3/4 ton pickup
1940 Chevy 1/2 KC Pickup
1939 Chevy 1.5 Truck
It sounds like that if you start it in neutral, you can't shift into gear with the engine running. Is that correct? You need to see if the clutch stuck in permanent engagement. You could put it in gear, use a prop to hold the clutch to the floor and then turn the engine with the fan belt. If that moves the truck, the clutch is stuck. There are various ways of correcting this without tearing things apart.
1951 1 Ton Completed
Heres a 1940 and one im building for my ten yearold
back yard wrench turner
My clutch has stuck engaged 2 different times. I found I could start the truck in neutral,let it idle for 30 minutes, it would build enough heat to release the clutch.
This has only happened after letting the truck sit for 30 days or more.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
