0 members (),
202
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 11 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 11 | 1964 Chevy C10, 230ci, powerglide. Somewhere there is a power draw that when the truck sits for a week the battery goes dead. Battery is in good condition. How do I track down this draw? I am not an automotive electrical genius, but tracking this down can't be that hard. Thx in advance.
Rick
Rick
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a quick check is to just disconnect the battery + cable while watching closely for a slight spark, which would indicate something active .... do you have a modern radio with presets? do you have a generator, or an alternator with idiot light?
Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | "Battery is in good condition." That belief has gotten more than one person on the wrong track. You can disconnect battery prior to a one week rest and see if it goes down anyway.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2010 Posts: 11 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 11 | Bill, truck had modern radio but no presets. Also has alternator.
Rick
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | alternators can cause battery drain under some conditions, although I can't tell you how or how to check it - someone should come along and clarify
Bill | | | | | Joined: Feb 2004 Posts: 29,799 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,799 | The simplest way to check an alternator for parasitic drain is to disconnect the main charging wire for a few days. The connector will be hot, so insulate the terminal with a few wraps of tape. If the battery stays hot, you've found your drain- - - -the alternator rectifier diodes.
If you're running the original-equipment alternator, the remote regulator can cause a battery drain also. If disconnecting the big lead at the alternator doesn't help, try disconnecting the 4-wire plug at the regulator. Jerry
| | | | | Joined: Apr 2011 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 45 | You might find it with a simple test light. Detach either battery cable. Attach the light between the battery and cable. It should burn if there is a draw. Find the circuit by pulling fuses one at a time and checking the light. Rustys link works the same but advises using a meter. You may have to search some after finding the guilty circuit to pinpoint the drain. I'm no expert, this is something I remember from a tech tip I read somewhere. Good luck.
All you can do is all you can do.
