3 members (farmallb, DaveV, Peggy M), 47 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#10775 05/07/2005 10:38 PM
Junior Member
Junior Member
does all 216:s interchange?any years I should stay away from?I have a 51 6400,and the motor might be frozen,and I have been offered one 41 216 that runs,but is expensive,and I have a friend that have a bunch of 216 laiyng around,but their probably 30´s engines,but cheap,any info would be good.
/ Vince
car nut for life!
#10776 05/08/2005 4:44 AM
Jed Offline
Swedester, I don't know alot about what you're asking but I can tell you my experience. I recently replaced the 216 in my 1946 truck with a motor out of a 1939 car. Worked just fine, but had to swap out flywheels because they're different, and mount to the crankshaft differently. The 46 had 6 bolts, (and keepers) and 3 or 4 dowels on the end of the crank. The 39 crank has no dowels, and only 4 bolts. I believe they changed this aspect around 1940.
I also had to modify my exhaust as the oil distributors on the drivers side of the block, are slightly different, and not in the same place.
I might be wrong, but I don't know that there is any difference between the 41 and the 51 motor. However, I'm sure someone will point out the errors I've overlooked.
Good Luck.
#10777 05/08/2005 9:10 AM
Junior Member
Junior Member
thanks!I´m a little more enlightend.
car nut for life!
#10778 05/08/2005 5:20 PM
Sweedster, 1941 -53 216s are practically all the same, with minor differences.
#10779 05/08/2005 9:19 PM
Junior Member
Junior Member
so the 41 engine has the same crank bolt pattern too?
car nut for life!
#10780 05/10/2005 4:58 PM
1940-41 uses a 6 bolt pattern but uses 3/8 bolts and the center hub that pilots the flywheel is larger.
My Blog
