1 members (52Carl),
105
Mod | | | Forums66 Topics128,062 Posts1,055,845 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | i have a 52 chevy 3800 1ton. i painted the interior 7272 color. can someone tell me the color of steering wheel and mask. thanks also if i can get it in spray cans | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | wow that looks good. But i'm confused, that color is a bronz and my steering wheel is gray. but your color looks gray. what am i missing | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | dad is that 7272 on interior. that is what i put on mine. what did u put on floor under mat. truck looks great | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I used the 7272 spray cans on the interior I covered the floor also with that same color but probably didn't need to because its covered with jute and a mat. here is the sticky for colors ...link... The paint I used kinda match what I found on my 50. But it may not be correct and of-course may not have been used on other AD years. If you used the 7272 the the 7754 is a good contrast for the wheel, mast and shifter. the color will not match the gray listed in the link above I painted my truck 4 years ago. The spray bombs have held up well. With the cost of the spray can now it may be cheaper to get the touch up gun from harbor freight and buy a quart of paint from one of the vendors. | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | why does your wheel look gray | | | | | Joined: Jan 2014 Posts: 86 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 86 | Hey Dads50,
Enjoyed then and now video.
Bob
1959 Chevy Apache Short Bed Step Side 1967 Cadillac DeVille Convertible 1967 Pontiac Firebird Convertible
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | why does your wheel look gray No sure, one pictures uses flash, the other is outside no flash. to me it has a purple tint ___________________________________ thanks Bob I appreciate that | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | ok i'll get it and yes your video is great. thanks for your help | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | check out Dennys comparison ...link... I thik he used "real" paint, not rattle can. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | You seldom can get much out of a picture, especially when it has been shredded into a billion pieces, transported, then re-energized on another computer (I'm pretty sure that's how computers work, right?). Carl
| | | | | Joined: Dec 2014 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 36 | I tweaked an existing martin senour color and it came out pretty close. If you mix 373 grams of 49727 warm grey and add 5.6 grams of 9842 russet red and 13 grams of ts218 black. It can be mixed in single stage, base coat with a flat clear or in rattle can. Dustin | | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | dad did u clear coat after u painted it. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I didn't use any clear on my interior
I've seen pictures whit the clear on it and they look real nice.
| | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | You seldom can get much out of a picture, especially when it has been shredded into a billion pieces, transported, then re-energized on another computer (I'm pretty sure that's how computers work, right?). Carl Beam me up Scotty...... LOL John | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | What kind of prep is needed for painting a steering wheel on a 1948. I have sanded off the previous owners paint and what was left of the original. Since it's paint on rubber is there any special primer or can I just use my rustolium rattle can primer. I am using the 7754 for the finish coat. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | I've seen some reference to Bulldog Adhesive promoter, which I'll use when the time comes. Seen it at the major auto parts stores. Mike | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Our local stores didn't have the Rustoleum adhesion promoter so I bought a Krylon product. I did a test spray on a piece of inner tube. Can't get more rubbery than that. I washed it with grease and wax remover, then the adhesion promoter, then Rustoleum primer, then the top color Rustoleum 7754. I wanted to see if there would be a reaction between the promoter and the primer since they were two different manufacturers. Came out great. No crawling or bubbles, and the paint seems really well adhered to the rubber. Now I'll get ready to paint the steering wheel.
