| | | Forums66 Topics128,031 Posts1,055,434 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | Can anyone tell me if the rear splash pan is the same on a 1946 chevy panel..as a 1/2 ton chevy. If so are there any venders who make repo's
1946 chevy 1/2 ton panel 1937 ford coupe | | | | | | Anonymous Unregistered | | Anonymous Unregistered | No this is not the same. I do not think the pick ups of that year even had rear splash pans. There are no reproductions of this very hard to find part. | | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | Hi, I'm new to the board,as a mater of fact this is the first post I ever put on but I can help with this. I'm building a '46 Panel also and I'm sorry to tell you but I spent almost a month looking for the rear roll pan for mine. Nobody that I found in the whole country makes one. I ended up making my own from some 18 ga sheet metal. It came out pretty good, just need it welded inplace now. If I can figure out how I'll post A pic of it and show you how I made it. I'll tell you now I'm not a metal worker but it did work.
David
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
