4 members (Bills Auto Works, moparguy, Southerntruck, Napco Man), 118 guests, and 2 robots.
Topics128,049
Posts1,055,680
#1075554 12/27/2014 1:29 AM
When replacing the rear gears do I need to replace the bolts on the ring gear?
Where do I get them?
Dennis
Ther are bolts holding the fly wheel on. The ring gear is a shrink interference fit on the fly wheel.
1951 1 Ton Completed
I think he's actually talking about the bolts for the ring gear in the differential, sometimes also called a crown gear.
Bill Burmeister
My mistake! I don't know how I missed that.
Most gear sets come with a bolt kit. But I have always used the old bolts if I just went through a third member and never had any problems.
No help here. Just saying howdy to Dennis. Figured you would have him on the road by now.
I have always reused the old ones unless new ones came in the kit.
My Blog
Howdy Martin. I hope all is well.
Thanks for all the replies. I bought the gears and install kit from Patricks. It did not come with the bolts. My installer ask for bolts saying it is best to replace them. I cannot find them nor their size. They're probably special bolts. I will keep trying. Thanks again.
Dennis
I doubt if any of the sellers of the 3.55 enclosed driveshaft R&P sets provide ring gear to carrier bolts.
Your old bolts should be safely reuseable unless they got mangled when removed.
I had the same concern, My kit came from Classic Parts but had a Filling Station sticker in the box. So I called them. They don't carry the bolts or know were to get them, but the gentleman said it is no issue to reuse the old ones. We did make guide pins and used the remaining 10 bolts to work it down into place all back together and torqued don with no issues. By the end of today all should be back together and moving along.
