0 members (), 159 guests, and 2 robots.
Topics128,260
Posts1,058,342
Members48,485
#10750 12/14/2002 4:11 AM
I have a 52' with the round core that seems to not produce any heat. So, it must be plugged-up. Should I pull it and run it down to the radiator shop? (what would they do and what's a fair price?) Or, is there something I can do at home on a beer budget?
Only thing I might suggest you try, if it is plugged with lime/scale, would be CLR, or some other type of product like that. Remove the core from the heater and try filling it with the above. Let it stand for a while then try flushing it through with a garden hose. Might work, might not. I think for a price they are reproducing new cores for the recirculating heaters. You buy them and reuse your tank ends. smile
Round heater core from my 48 was plugged with very low flow, but did not leak. It was suggested to try flushing with white vinegar. The white vinegar flush really worked. Now water flows freely thru the core, but flows even better thru all the leaks that were unplugged during the flush. Replacement cores are insanely expensive
1948 Chevy
5 window
"6" powered
