0 members (),
81
Mod | | | Forums66 Topics128,179 Posts1,057,160 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,844 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,844 | What I'm showing below is apparently a seam of the upper and lower back section of the cab. It's been kinda rusty for a few years but I also notice that the lower section protrudes out further as compared to the upper section. Also and probably more importantly is that the driver's side lower section sticks out further than the passenger's side. Is this a common body problem for these trucks and how does one fix it ? I was getting ready to wire away the rust and touch the area up when I noticed this. Like my vintaged weather stripping? Maybe that's the cause for what's happening below? http://community.webshots.com/photo/169266715/169267113NLAbZZ
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Craig - these trucks were assembled by "and eye for fit and finish" - perfect alignment was never expected.
That seam has always been a source of rust. I have bead blasted, etchant primered, filler primered, sanded, sealer primered and top coated only to have it start a new bit of rust bubbles within 5 years if the truck spends any time at all outside in the rain.
If done as described above in your weather conditions, I bet you could get 10 years+ without problems. | | | | | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | I've had the same problems. Thought next time I might weld the seam shut. My wife has a 47 second series, VERY poor fit.
Jason
| | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | I had to completely remove the rust all along that seam and replace it with solid metal. No seam any more, just the contour. | | | | | Joined: Jan 2002 Posts: 2,844 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,844 | Keep forgetting that vehicles back in those days were not computerize assembled. My cab was probably welded on a Monday morning after the crew spent the entire weekend on a binge. Oh well, gives it a little character.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | What amazes me on these old cabs, is the random nature of the spot welds. They are not evenly spaced by any stretch of the imagination. I wonder if the instructions they worked with were to put X number of spot weld along a particular joint line. | | | | | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | That seam on our '52 looks the same as yours Craig. I cleaned the seam the best I could, then "soaked" the seam with that "rust-converter" solution stuff. (small bottle...'Kleen-Strip' brand) I let it dry a couple days between applications. Then we primed and painted. I had tested the converter on rusty spots on the interior of our washing machine....tough stuff. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Since my paintjob's delay my joint started rusting again after it had been sandblasted. I got this skinny brass wire wheel that fit right in there and made the whole joint shiny. As a stop gap to rust reappearing before that fabled paint job I just sprayed some Zero Rust into the joint. The whole thing will get sanded down again any way.
54 3100 with 235 62 flatbed dump C60 with 261
