| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 56 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 56 | I want to put a 250 L6 into my 1956 Chevy Belair. Do that block have side engine mounts or the thin bolt like mounts that are at the front of the engine? | | | | | Joined: Jun 2007 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 56 | They're on the side and the mounting pad is flat against the block. I had to get mounts from Chassis Engineering Inc. I had to piece some together for my truck with a 250. Engine mounts for the 250 and frame mounts for an AD truck with a MII front end, both from them.
1947 Chevy 3100 - Shop truck - 250 L6/T5/4.10's 1970 Chevy Camaro - Rotisserie jail
