0 members (), 94 guests, and 3 robots.
Topics128,093
Posts1,056,474
Members48,444
I have a '53 3100 with the original rear axle assembly, and I'd like to put some wider rear wheels on it.
Wheel Vintiques sells 15x8 artillarys w/ 4.0" backspacing.
Can anyone tell me if those would fit on the back of my truck w/o rubbing the inside or outside?
Thanks-
Ben
No, it's not. I'm not sure what measurement GM used. These days, offset is the distance of the wheel mounting surface from the center of the wheel, and the backspace is the distance of the wheel mounting surface from the back face of the wheel. So a 15x8" wheel with a 4" backspace has 0 offset.
SeatGuy, it depends what tires you're running as well. Is your truck stock height? Have the springs been replaced or are they original?
Someone else will chime in about whether they'll fit, but these are all things to think about.
My 46 GMC on Photobucket
Diagrams on the internet suggest suggest a different story. They show the ridge at the edge of the wheel factored into the backspacing.
Diagram
