| | | Forums66 Topics128,142 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 55 Member | | Member Joined: Nov 2002 Posts: 55 | The brake pedal in my '55 2nd 1/2 ton is connected to a shaft that goes through a hole in the floor. It connects to an "arm" that hinges on the master cylinder.
I'm trying to get those 2 parts disassembled (pedal shaft and arm). There's a castle nut holding the brake pedal shaft to the arm, but the 2 parts are stuck together pretty solidly.
Do those parts thread together or is it a press fit? Would a small puller tool get them apart? Anyone done this? LT | | |
