4 members (Ponchogl, TUTS 59, WICruiser, stlcardinalsguy), 79 guests, and 2 robots.
Topics128,035
Posts1,055,564
#107415 09/15/2003 5:41 PM
How do you remove a windshield?
Without useing a hammer of course.
#107416 09/15/2003 5:43 PM
If you dont intend on using the rubber that is already on the truck again, use a utility knife and cut away the rubber and the glass will pop out with a little nudge. Also remove the center piece first.
1953 Chevy 3100
The Green Truck
#107417 09/15/2003 5:53 PM
The rubber is in great shape. I would like to reuse it.
Thanks.
#107418 09/15/2003 8:42 PM
tttt8, check your email smile
