1 members (78buckshot), 112 guests, and 1 robot.
Topics128,136
Posts1,056,425
Members48,441
#1072779 12/11/2014 1:02 PM
All,
I wanted to get everyones thoughts about their dual carb setup? What works and why etc.?
I am now thinking of using Carter W-1 574 or YF 966....
Look forward to everyones setups,
Steven
Take care,
Steven
No one can drive us crazy unless we give them the keys.
Steven,
This topic is discussed at least twice on month (maybe once a week).
Try a Search here (or, use Search in the menu above):
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=search
Search for "dual carb"
Do not type in a name in Display Name Search
Search back Newer Than 1 Year (more years, if you have the time).
After reading a few (dozen) threads, you should come back with your questions.
Note that the carbs that might work on any particular 235 set-up will most likely not be well-matched to any particular 261 set-up.
Will do. Thanks Tim!
Take care,
Steven
