| | | Forums66 Topics128,095 Posts1,056,069 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 12 Member | | Member Joined: Feb 2001 Posts: 12 | in about 2 weeks are so i am going to be getting a 58 3800 to convert to a 4 dr with a long bed my question is where a re the factory seams at on the cabs the one to put the roof on the back. i also have a 58 3200 i using the cab and bed in the conversion | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if yer makin a 4door you won't be usin the factory seam - it's on a line around at the level of the rain gutters. the roof stamping is one large 'pan', and to make the roof line work you'll probably hafta patch a piece in. good luck!
Bill | | | | | Joined: Feb 2001 Posts: 12 Member | | Member Joined: Feb 2001 Posts: 12 | what can i use as a patch ? | | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | What about a partial roof skin from a similar year panel truck or suburban? Wannabe
"Don't expect anything and you'll never be disappointed"
