| | | Forums66 Topics128,087 Posts1,056,375 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 41 |  what kind of kingpin bushing do i have? Do i have the floating kind or fixed and need to ream them out to fit, if so there in the world would i find a reamer for that? thank for reading. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | These are not full floating king pins. The king pins are rigidly held in the axle and the spindles are bushed. You could press them in your self but you're better off taking them to a machine shop to get them honed. It would be expensive buy a reamer long enough to achieve the line bore required and even then, honing will give you a much better fit. dg
Denny G Sandwich, IL
