| | | Forums66 Topics128,079 Posts1,056,301 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | Hi Everybody
I finally got "Howard Knapp" a 1953 Chevy 1 ton I purchased last winter into the spot in the garage where we can work on it...first order is to get it to roll safely. The rear main leaf spring is broken on one side, there is also another set of helper leafs over the top of the main stack. I wont be loading this thing with a "ton" of weight so I am wondering will a lighter set of springs (maybe 1/2 ton) fit on this truck? without a ton of modifications I am hoping.
Also can I lose the extra set of helper springs without any issues to the handling of the truck???
Any insight would be a wonderful thing.
MikeC 1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | Hi White Dog
I have a friend that works for a locally owned truck spring shop. Would it behoove me to maybe hand over to him the broken leaf and have him build me a new one?? The truck is originally from New Mexico so the rust is not too bad. Just lots of dirt and grit in and around the leafs.
He told me earlier he can build springs from scratch if he has the old to to compare it to.
Also those 2 links you gave me. Are they decent folks to deal with?
MikeC 1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I haven't ordered anything from either one. I have talked to the Suspension King guys. Seem like a good outfit. They build springs in house, order by order basis.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have delt with Eaton Detroit Spring and was pleased. | | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Zenith up in Duluth MN will build a new leaf to mfr spec as well. Decent prices, good service Good luck! | | |
