1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 12 New Guy | | New Guy Joined: Oct 2014 Posts: 12 | I know a little about working on motorcycles, but I am first time attempting to do a simple change of shocks on my '52 3/4 ton Chev soon. I was wondering, do I need a spring compressor or will they slide right on if I have jackstands under the frame so the suspension hangs free? Also, I suppose I have to wait until I can get my hands on a impact driver to get those shock nuts off? I have already sprayed them with break-free fluid (coon [censored]) to break the rust up, they are the original shocks on there!
I hate new trucks! My menagerie: 1952 Chevy 3800 "Ol' Blue '52" 1979 Chevy C-10 "Ol' Red" 1968 Triumph T100R
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | you won't need a spring compressor. Just remove the nut on top and bottom and they should pull off! | | | | | Joined: Oct 2014 Posts: 12 New Guy | | New Guy Joined: Oct 2014 Posts: 12 | I just want to be sure I can get the new ones on, since they will be quite stiff and impossible to compress by hand. I have only had shocks replaced on my other vehicle once, and I had a garage do that. I get tired of paying someone to do simple tasks!
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I recently put shocks on both my '54 and '56. The shocks are packaged compressed with a band holding them. I installed one end then cut the band and let the shock extend as I guided the other end into place. | | | | | Joined: Oct 2014 Posts: 12 New Guy | | New Guy Joined: Oct 2014 Posts: 12 | OK, will give that a whirl, once I can get the holding nuts off!
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Try a propane torch. Try not to set the rubber bushings on fire. | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | I did the same as Cletis... worked just fine! I had to get new rubber bushings... which my shocks came with (yippee) | | |
