| | | Forums66 Topics128,087 Posts1,056,107 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 63 | 1948 Chevy 3100 truck Turn signals- Turn signals were added to my truck at some time and the prior owner said they did work but they don't now. Any advice before I go searching; Is there an inline fuse or a flasher unit?
Heater blower motor- Same thing I do not hear a motor when I use the heat switch; is there an inline fuse? My truck has had the vintage A/C installed so it blocks the blower. I see no control of any kind for this A/C or compressor, etc. How does it work?
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Both of the accessories you list were options, either dealer installed or aftermarket installed by who knows who. How they were wired varies with each installer. I wrote a turn signal tech tip that should be helpful. If it has a Vintage Air brand unit it probably has the heater in it. Sounds like some of it is missing. Check their website. | | |
