3 members (68ironhead, Gray_Ghost, pauld), 80 guests, and 3 robots.
Topics128,268
Posts1,058,393
Members48,485
I need to remove the old engine mounts on a 1983 S10. There doesn't seem to be any easy access to the nuts on the inside of the frame. Is there any way to get at these without having to cut into the frame? I'll also need access for the new mounts.
Whenever you leave behind failure that means you're doing better if you think everything you've done has been great you're probably dumb
-Louis CK-
'53 GMC
If you jack the truck up sometimes you can take a long extension with a swivel socket and go up through the opening in the crossmember where the lower a-frame connects.
Yeah I actually got them out. I was taking out the whole wheel assemblies anyway and you can quite easily get at the nuts. Thanks for the suggestion.
-Louis CK-
'53 GMC
