5 members (Woodcmiami, homer52, Wheelie, Wally / Montana, 1 invisible), 120 guests, and 4 robots.
Topics128,042
Posts1,055,519
Members48,424
#1071186 12/02/2014 5:48 AM
I have a 1951 3800 with the following information:
Engine Casting Number - 3835911
Head Casting Number - 3836848
Engine Serial Number - HCA408364
I have researched and found that the engine is a 235. Is this correct?
I can't find the Serial Number anywhere. I can't find the head and engine casting numbers together based on the research and sites I have reviewed.
Any help on figuring out what I have?
James
3835911 is 54-55 235
3836848 is 235 also but usually from later years. it may have been a replacement head. Good possibility you have a early conversion from a 216 to a 235
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
3836848 was used from 1956 onwards
HCA408364
HCA was the Engine Serial Number used on 1950 4400 series truck - 216 engine
AHCA was used on 1950 3800 216 engines
As posted above by thoroco (Dave), this is not the truck's original engine.
Post the date casting codes (head and block) for more information about your engine.
Thanks for the info.
Date code for block - CON3 B225
I can't get to the head date without taking cover off, correct? If so, I will have to get that date at a later time.
I do have a Bowen Machine emblem attached to the engine with the following info:
Date: 7 68
No. 1114
Cyl: 040
Rod 010
Main 010
This is a picture of it
http://i1373.photobucket.com/albums/ag392/jamescwade/DSCN0214_zpsb8f41f24.jpg
B225
B = February
22 = 22nd
5 = 1955
That block casting code, 3835911, was used from 1953-1955 on high-pressure 235s used on trucks (up through first series 55) and 53-55 Corvettes. It should have mechanical lifters and it should have the higher-mounted, earlier water pump (in the correct location for 1951 radiator). The fan belt is most likely 3/8" wide.
CON3 = Foundry plant, Conveyor 3
