7 members (FAST55, 2-Ton, Reftys49, Eisenholtz, MickeyP, Oswald, Ponchogl),
117
Mod | | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 15 New Guy | | New Guy Joined: Nov 2014 Posts: 15 | I have a 1951 3800 with the following information:
Engine Casting Number - 3835911 Head Casting Number - 3836848 Engine Serial Number - HCA408364
I have researched and found that the engine is a 235. Is this correct?
I can't find the Serial Number anywhere. I can't find the head and engine casting numbers together based on the research and sites I have reviewed.
Any help on figuring out what I have?
Thanks, James | | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | 3835911 is 54-55 235 3836848 is 235 also but usually from later years. it may have been a replacement head. Good possibility you have a early conversion from a 216 to a 235 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 3836848 was used from 1956 onwards HCA408364 HCA was the Engine Serial Number used on 1950 4400 series truck - 216 engineAHCA was used on 1950 3800 216 engines As posted above by thoroco (Dave), this is not the truck's original engine. Post the date casting codes (head and block) for more information about your engine. | | | | | Joined: Nov 2014 Posts: 15 New Guy | | New Guy Joined: Nov 2014 Posts: 15 | Thanks for the info.
Date code for block - CON3 B225
I can't get to the head date without taking cover off, correct? If so, I will have to get that date at a later time. | | | | | Joined: Nov 2014 Posts: 15 New Guy | | New Guy Joined: Nov 2014 Posts: 15 | I do have a Bowen Machine emblem attached to the engine with the following info:
Date: 7 68 No. 1114 Cyl: 040 Rod 010 Main 010
This is a picture of it http://i1373.photobucket.com/albums/ag392/jamescwade/DSCN0214_zpsb8f41f24.jpg | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | B225 B = February 22 = 22nd 5 = 1955
That block casting code, 3835911, was used from 1953-1955 on high-pressure 235s used on trucks (up through first series 55) and 53-55 Corvettes. It should have mechanical lifters and it should have the higher-mounted, earlier water pump (in the correct location for 1951 radiator). The fan belt is most likely 3/8" wide.
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | CON3 = Foundry plant, Conveyor 3
